small motor man
- Jul 21, 2014
- 6
- 22
I have a 16 hp Briggs that I'm working on for a customer and for a week I have had it when it showed up I first realized that the engine mount was loose but why it was brought to me was that the engine would worm up and stall so I changed the coil and cleaned the fly wheel then changed the plugs ( no points ) and it was having a gas problem so I cleaned the carb and that fixed that so it was running strong as ever so I gave it the requested tune up ( belt change oil change ) and sent it back and within 10 minutes I got a call it had quit so I went over to see and it had quit but it wouldn't turn over either then I put it in first and it turned over so I put gas in the carb and it started so he went on mowing and it quit again so I took the topper off and it seamed hot to me so I let it cool down and it started again and this time it ran without the topper for about 30 minutes and the customer won't give up on it but I can't tell him nothing it's done him well I think it is a 1972 co-op turf trac 16/44 and he's never done any maintenance on it but I'm to fix it and was wondering if any one has had this problem or if the tractors that old
SMM
SMM
