Results 1 to 7 of 7
  1. #1
    Join Date
    Jun 2012
    Posts
    Location
    North Carolina
    Mower
    Husqvarna
    Husqvarna will not crank without carb cleaner
    I have a Husqvarna riding mower, model YTH23. The only way I can get it to crank is by taking the air filter off and spraying carb cleaner down the carb. After this, it cranks up and runs great. If I let it sit for more than an hour or so, I have to spray the carb cleaner again to get it started. Can anyone help with my problem?
  2.
  3. #2
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Re: Husqvarna will not crank without carb cleaner
    WELCOME to LMF....
    I think I follow what you are saying... although your terminology is wrong....
    I think you are saying, it cranks fine,(cranking is done using the electric starter motor), but the engine will not start unless you spray a flammable liquid directly into the carb...
    You are having a fuel delivery problem for sure... If I have interpreted you correctly.
    Start at the carb, disconnect the fuel line and check that you get fuel to that point....
    KennyV
  4. #3
    Join Date
    Jun 2012
    Posts
    Location
    North Carolina
    Mower
    Husqvarna
    My terminology isn't correct. And you're right. It will crank fine but will not start. It has a fuel pump and I disconnected the fuel line from the carb and gas came out. So I think fuel delivery is ok? Problem with the carb?
  5. #4
    Join Date
    May 2010
    Posts
    5,447
    Location
    Mower
    CTL
    Quote Originally Posted by catthead View Post
    Your problem will be at the carburetor...
    First place to check is the float & float bowl.
    You can see the carb cleaning & check procedures at:
    part 1, Disassembly, Cleaning and Repair of Briggs and Stratton Intek V-twin Two-Barrel Nikki Carburetor - Part 1
    part 2, Disassembly, Cleaning and Repair of Briggs and Stratton Intek V-twin Two-Barrel Nikki Carburetor - Part 2
    Before getting into the carb, check the solenoid under the carb to see that it is getting 12 volts with the ignition key in the on position... You should hear/feel it click when you turn the key to on. (that is item #4, pictured in part 1 above.... KennyV
  6. #5
    Join Date
    Jun 2012
    Posts
    Location
    North Carolina
    Mower
    Husqvarna
    Thanks! I'll check it out this week!
  7. #6
    Join Date
    Sep 2016
    Posts
    Location
    California
    Mower
    Husqvarna
    I am having the same exact problem. Did you find a fix for this?
  8. #7
    2,500 Post Club
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    4,563
    Location
    Missouri
    Mower
    RZ5424
    Quote Originally Posted by mowerloser View Post
    This thread is 4 years old. Please start a new thread and include your mower model number and engine model number. We will be happy to help.
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
Similar Threads
  1. Replies: 11
    Last Post: 03-24-2013, 04:15 PM
  2. Carburetor Leaking Into Air Cleaner
    By Mac1963 in forum Small Engine & Mower Repair
    Last Post: 05-03-2012, 02:07 PM
  3. Homelite timmer, fuel coming out air cleaner..
    By russcrisp in forum Homelite Forum
    Last Post: 05-02-2012, 08:02 PM
  4. Carb Cleaner
    By RobertBrown in forum Small Engine & Mower Repair
    Last Post: 08-22-2011, 11:13 PM
  5. Best vinyl siding cleaner?
    By JDgreen in forum The Front Porch
    Last Post: 07-25-2010, 07:35 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
