Results 1 to 10 of 10
  1. #1
    Join Date
    Apr 2018
    Posts
    4
    Location
    United States
    Mower
    Toro
    TORO Recycler losing oil - not from oil tube
    I just purchased this Toro used. I t was cleaned and dried by previous owner. I brought it home and filled the gas and topped off the oil. About 20 minutes goes by using it and I see oil leaking out the side of the motor. I have attached pictures. Do I need to pull it apart or is this an easy fix. I tried searching, but mostly found oil tube leaks.
    Motor: Tecumseh 195cc
    Model LV195EA
    Attached Images Attached Images
  2.
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,639
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: TORO Recycler losing oil - not from oil tube
    The best way to find a oil leak is start with a very good cleaning. Then run it and keep watch around the area of the leak to find it.
  4. #3
    Join Date
    Nov 2014
    Posts
    7,908
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    And while it is till damp a good dusting with talcum powder or something similar.
    Let it dry off so when you start up you will have a nice white coating for the oil to bleed through.
  5. #4
    Join Date
    Apr 2018
    Posts
    4
    Location
    United States
    Mower
    Toro
    It was clean and dry to start. The oil is coming from above the threads in the picture.
  6. #5
    Join Date
    May 2011
    Posts
    5,639
    Location
    Marion,NY
    Mower
    Quote Originally Posted by idriv442 View Post
    New crankcase gasket time. You will have to remove the engine from the mower frame for this repair.
  7. #6
    Join Date
    Apr 2018
    Posts
    4
    Location
    United States
    Mower
    Toro
    Thanks.
    Now to get one ordered. Anyone have a part number?
  8. #7
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    4,143
    Location
    Central Fl. about 2 hours from DAYTONA !
    Mower
    Murray Select 21 H.P. 46" ( 2004 )
    Thanks.
    Here's the place for your manual........ http://www.barrettsmallengine.com/te...alengines.html
    You can find what you need in here, DON"t expect the tech's here to do ALL the work you can do for yourself !
    Mower : Murray Select 46 " deck
    Model : 465306X8A
    Serial # : 733781D027
    Date of Mfg. : 2003/12/03
    Engine : Briggs & Stratton
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
    Family YBSXS . 7242VF 22844
  9. #8
    Join Date
    Apr 2018
    Posts
    4
    Location
    United States
    Mower
    Toro
    Thanks, I actually already have it ordered and in the mail. Just waiting for it to show up.
  10. #9
    Join Date
    Oct 2013
    Posts
    40
    Location
    Pennsylvania
    Mower
    Toro
    While youre tearing it down, I'd stick in the oil seal at the bottom of the engine
  11. #10
    1,000 Post Club
    7394's Avatar
    Join Date
    Sep 2014
    Posts
    1,175
    Location
    Tennessee
    Mower
    Toro Z w/Kawi
    Is that a scratch on engine side you have circled or a crack ?
    Buddy aka: Numbers
Similar Threads
  1. Replies: 7
    Last Post: 10-10-2017, 08:26 AM
  2. Engine Toro Recycler 20031 from 2004 leaking oil on top of deck
    By rkhanso in forum Toro/Wheelhorse Forum
    Last Post: 06-01-2016, 02:22 AM
  3. Dipstick Oil Tube Leak at O-Ring
    By Rick'sToro8-32 in forum Small Engine & Mower Repair
    Last Post: 04-20-2015, 08:30 AM
  4. Toro Recycler Blowing White Smoke and Leaking Oil
    By pcfast in forum Small Engine & Mower Repair
    Last Post: 08-11-2013, 01:22 PM
  5. Tecumseh Motor losing oil?
    By guitfiddler in forum Tecumseh Engine Forum
    Last Post: 04-23-2012, 10:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
