how do you the idler spring reattached when you replace drive belts. I cant even get it close.
M mipe54 Forum Newbie Joined Jun 3, 2017 Threads 2 Messages 2 Jun 3, 2017 / idler spring #1 how do you the idler spring reattached when you replace drive belts. I cant even get it close.
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,768 Jun 3, 2017 / idler spring #2 I was going to respond with a very rude comment, but I'll be nice. We have no idea what you are talking about. You need to provide us with more info if you want help. Make, model and serial numbers would get you some help.
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Jun 3, 2017 / idler spring #3 I made a tool for this called a trampoline. Its just a rod with a hook on one end and a handle on the other.
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Jun 3, 2017 / idler spring #4 reynoldston said: I made a tool for this called a trampoline. Its just a rod with a hook on one end and a handle on the other. Click to expand... I made a tool for this called a trampoline spring pulling tool. Its just a rod with a hook on one end and a handle on the other.
