- Nov 29, 2014
- Threads
- 64
- 24,705
Before you connect the the electronic points eliminator please give the ignition switch a tub as per my previous post.
The modules are very sensitive to CURRENT ie AMPS and will fry if hooked up to a battery.
No idea is your 0.1 V will be a problem when running or if it is an accurate reading but at $ 50 a pop a good soak in WD 40 and some wiggling of the key is cheap insurance.
The module is based on the Atom unit invented down here in the early 60's but not universally adopted till the 90's when the patients ran out.
I can not see $ 50 value in it as the chip is around $ 1 .
Old Atoms are around $ 20 to $ 30 and the briggs module is around $ 20.
