Quick Change Blade Assembly Change Out
eltut
Does anyone have experience with removing the quick change blade assembly and replacing it with a five star adapter? A lot better blade selection is available!
Yes but you will have install new spindles. Still way cheaper trying repair the quick change blade adaptors when they are bent. They were around $152 each vs $35 spindles on the last unit I changed over..
What is the model number of the mower from serial number decal?
dogthenine
I have a YT46LS, I want to replace the spindles to eliminate the quick change blade system. What part number spindles do I need to get to accomplish this?
587819701 Non Greaseable
587520301 Greaseable
and new 5 points star blades 532405380
That PN (greaseable version) has been superseded...
dogthenine
Thanks, so they're the same; the part number you supplied is just a newer one, right?
