GearHead36
- Apr 26, 2023
- Threads
- 10
- 142
Is there a balancer out there that is better than the cones, but doesn't cost a fortune? I'm just a homeowner. I have several blades to maintain each year, but I don't have a need to balance hundreds of blades like a shop would, so I can't justify a top of the line balancer.Those cones usually has steps rings which poorly fit the blades so you could blade off center.
And hopefully the RPM meter is set to one count per revolution. But if the mower cuts well at 2900 rpm then just leave it at that. Usually you will have more Ft-Lb torque at the slower speed.
It's definitely NOT running at 5800, so I'm pretty sure the tach is giving the right readings.
