Scag scz61v-34kh hard to crank
I have heard of the issue and was discussed at a Kohler update a few years back, but like you said no real solutions were given. Some of the Briggs big block Vanguards have a similar issue with kickback when trying to restart while hot.
VegetiveSteam
Where did you typically attend Kohler updates? Effingham?
We've probably seen each other.
If you were at the Knights of Columbus hall with Don Whitacre, and Gary Febig(sp?), and Brian Jones there is a very good change that we have spoken.
VegetiveSteam
Yeah Fiebig. I put on some of those meetings. We would rotate.
crazy Greg
Yes it did, it will crank over the same with plug wires attached without the choke on. I have a fully charged battery & installed a new starter also. I'm baffled by this.
