Chesterspal
- Aug 27, 2023
- Threads
- 1
- 7
At my wits end with this engine. Three weeks and still the same issues. Cannot keep it running w/o misfires, backfires, loss of power, stalling out.
I’m usually pretty good (with my machines) but this one has me stumped.
What I’ve replaced:
Carb
Points
Spark plug
Ignition wire (w/solid copper core)
Have new coil and will do that next
Played with the points. Book says .020”. Set anywhere from .022 to .015 with little difference. Seems a tad better with the smaller gaps.
I have a timing light but hard to see through the hole. Might remove cowling if you feel it will help me get this right.
Timing light is erratic when running. Coincides with the mis/back fires as you’d expect.
I think this is more to do with ignition, not fuel.
Suggestions?
Can post videos if this site will let me (?)
Thanks
What I’ve replaced:
Carb
Points
Spark plug
Suggestions?
Thanks
