- Nov 29, 2014
- Threads
- 64
- 24,729
Profanities should not be used on open public forums or open radio channels
IT is some thing I picked up from a radio dispatcher decades ago
IT gets very frustrating when people who obviously do not know what they are talking about demand proof that I know they would not understand even if they could access it and of course defence documents are not publically available and university papers are all behind pay walls , if they are actually available from pre internet days
Even the simplist of people can go to any oil blender and most will happily show them how they blend their secret formulas and a general idea about what is in them.
There are literally millions of molecules that can get added to oils to modify the behaviour of the base oil and they are needed because the chemistry of base oils differ depending upon where they come from.
Near 1/2 of the heavy lubricating oils used in the USA come from Australian oil fields because the crude from Bass Strait is perfect for lubrication as it has a high sulphur contents ( bad for auto & syncromesh boxes )
And then you get the stuff that oil companies like to brag about like ZZDP which is not needed in a mower engine at all as the scuffing forces between the cam lobes and the cam followers is just not high enough unless the owner has fitted high strength valve springs
On top of that a lot of the cams are actually powder pressings so retain enough oil in their pores to maintain boundary lubrication for the time the followers are in contact with the cam and because the whole shooting match is vertical & not horizontal and lubricated by splash & oil mist , not a pressurised flow through a an oil gallery .
