B&S 17 tooth starter
BigAl621
Looking for a B&S 17 tooth pinion gear or complete starter OEM model 698162. The B&S motor is a 21M317-0115-E1. It is on our Ariens 36” snowblower. Need above or any possible alternate solutions. I can reuse the electrical regulator attached to the motor as seen in the photo.
Welcome to new world of post Briggs bankruptcy. It seems that everything is going NLA.
So dang frustrating trying to repair anything Briggs lately.
BigAl621
You might check try.
Thanks. I did with no luck. The actual pinion gear is fine, just the black plastic part that connects to the back of it exploded. Wish there was a way to McGiver something like it to make it all work. There’s got to be something out there that would be close enough with a little work to make it all work. Getting frustrating at this point. The motor is great and the snowblower works fantastic!
Take a nice clear photo & post it
Good chance you are not alone & there isa work around
BigAl621
Here is the motor. I can reuse the electrical regulator attached to the motor as seen in the photo.
