- Nov 29, 2014
- Threads
- 64
- 24,727
A top bearing failure is always low oil.
Usually the oil level gets low and then the mower is run along a slope.
This means that the oil pump inlet is above the level of the oil.
There is about 1 to 3 minutes worth of oil in the top bearing housing.
So a slope that you have mower 50 times with out problems will suddenly cause an engine seizure because the oil, while being within the two oil level lines, is just that tiny bit too low.
On vertical shaft engines the sump is a big flat pan so a very small difference in the slope can make a very big difference to the oil level at the pump.
I have even seen a case where a partially flat tyre allowed to oil to sit lower than the pump inlet screen.
