It may have a separate charcoal canister. My Kawasaki Mule SX has a similar setup. My Mule has a standard fuel filter like that and a charcoal canister.It is supposed to be charcoal impregnated to capture fuel fume
Solid Machine you have there.It may have a separate charcoal canister. My Kawasaki Mule SX has a similar setup. My Mule has a standard fuel filter like that and a charcoal canister.
OP: By the way, that’s not a fuel line, that’s the venting lines. The fuel line has the larger outside diameter and goes to the larger filter in the right of the photo.
Don’t overfill your fuel tanks. There should be something in your operators manual about filling your tanks. The bottom of the filler neck is usually a little below the vent and fuel lines in the tank. Fill just to the bottom of the filler neck.I thought my ISX2200 was leaking oil, Turned out to be fuel coming out of that vent filter when tanks are full, I placed a hose on open barb and ran it down towards ground behind hydro. seems to have cured problem.
