7394
- Sep 5, 2014
- Threads
- 84
- 4,847
It was a 4x4 that I cut to size, to sit on the 4 protruding steps under the wood block. I first shaped the 4x4 so the OE filter flap would just close. And I lag screwed from everywhere there are arrows on my illustrations. Then thru the cover to hood down the bracket.It's hard to get perspective on the block you installed in the old air box space. Do you have dimensions for it, or another picture that better shows it's shape? I like what you did here and want to do the same. Also, is this the kit that actually shows for the the FX motor?
I got the canister & brackets used off ebay, for an FX 730, but put in new filters. Now depending on your elevation, you may need to re-jet to a leaner size jet.
No kit on mine, I built it my way.
