Kawasaki FD791D Issues .
Hammermechanicman
Have you checked that the air pressure sensor is changing voltage when the engine cranks? Sounds like you have an ecu input problem. If you have checked the injectors and swapped the ecu that pretty much leaves an input to the ecu not working. Check the wiring connections to the sensors.
Luffydog
But it hits with either so it is firing
Luffydog
Take fuel line off and see if it squirts fuel out line might have a blockage
Luffydog
Had one today doing the same thing with low compression adjusted valves then compression cane up and then wouldn't start because of fuel line was blocked
Curious what is the spec number the FD791D?
