- Nov 29, 2014
- Threads
- 65
- 24,804
Thanks for spending the time with all of this info. Believe me I'm not stressing at all. I use a high zinc content oil in some of the flat tappet engines I work on because of cam break in issues. I have a Toro 21 inch lawnmower with a Suzuki engine it and is 26 years old. Doesn't burn a drop of oil and gets synthetic Amsoil oil each year. Like I said earlier I'm not familiar with small engines and I know they are different in many ways so I'll keep on learning.
Thanks
I hope the Suzuki burns some oil as it is a 2 stroke , and a very good engine it is too.
I have a couple of them here fitted to 24" Big Bobs and they run flawlessly. How much is due to the Mikuni carb is another question.
Not quite up to the standard of the Victa power Torque which was too good for the USA so your government invented "safety problems" and banned it thus you are unlikely to see one.
When I bought the repair run the vendor spent 1/2 the day reciting "it is a lawnmower, not a space shuttle" and it still took me several years to come to terms with the design & build quality.
I was appaled the first time I pulled one apart & found not only did it have no bearings inside but there was not even a thrust washer between the crank & the sump casting , the engine relied entirely on splash and the filter did nothing but filter some of the oil in the sump that was not being splashed around the engine .
Then the idea of setting end float by using different thickness sump gaskets ( which compress when tightened ) had me scratching my head wondering how these things managed to run al all.
