gregjo1948
- Nov 28, 2012
- Threads
- 75
- 362
That is the fuel pump. There should be another line(hose-tube) that goes into one of the valve covers. When the piston goes down, it pulls a suction on that hose going to the fuel pump and draws the gas from the tank to the carb. If you pull the gas line loose from the carb and crank the engine over, gas should squirt from the line. If not, check the line going to the valve cover for cracks, splits, or holes.
