JDgreen
- May 14, 2010
- Threads
- 248
- 2,887
JD, Just because I'm curious ...... What blades etc. have you tried ??????
I had a 318 and had very little problem with clumping and a 2nd pass would nearly always solve the problem.
BK, I had a 318 myself, and it would chop up grass a LOT better than my 4210 does, my cop neighbor has a small Craftsman lawn tractor and his deck chops up grass a lot better than my JD does. I am currently using Gator mulching blades, only about 40 hours on them. My deck simply will not recut grass worth a (BLEEP) instead it just picks up the cut stuff and blows it back out.
Took this picture last night, I was cutting dry 5 1/2 inch high grass with the mower deck set at maximum cut height of 3 3/4 inches, and the discharge chute was propped open, yet look at the grass clippings piled up in front of the deck !!! GRRRRRR!!!!!! The deck cuts grass so poorly the grass clippings lie on top of uncut grass blades and the front of the mower deck plows them up.
