Craftsman model 37068 self propelled push mower with briggs and Stratton platinum engine (pull start, 190cc I think) little over 6 yrs old
Mower will start using starting fluid but can’t keep running for very long while injecting fluid (maybe 15 sec).
Short story, had a valve seat come loose, repaired, ran fine then didn’t.
Carb was leaking, installed new carb (p/n 799866), cleaned gas tank and line, added new gas, new plug.
Won’t start except with starting fluid. Carb has fuel in bowl. Can see spark on plug when placed against head while cranking.
Checked compression with gage while pulling to start – 40-45psi first pull, 60psi 2nd pull.
Not sure where to go next. Seems to point to lack of fuel but not sure why that would be with the new carb.
Leakdown test?
Ignition coil? (could spark be weak when under compression?)
Ignition timing / keyway problem?
Maybe a vacuum leak at the intake manifold/cylinder head gasket?
I really hate the idea of disposable machinery so I’d like to sort this out so any help is appreciated.
More details below if needed.
Long(er) story -
Problems started over the past few months of intermittent use (maybe 2-4 wks between use).
First problem arose after the mower sat 2-3 wks. – tried to start and heard metal – thought a stuck valve might have contacted piston.
Ended up being the valve seat pulled out but no major damage.
I carefully tapped the seat back in place checked valve operation (no sticking) and bolted everything back together with new spark plug.
Started fine and ran like it had been for a couple mowing sessions a couple weeks apart.
Sat for maybe 2-4 weeks. Tried to start – no go. Carb leaking gas.
Cleaned out carb (not gummed up) new seat, needle, gaskets, blew out jets.
Carb still leaking, thinking float but said screw it and ordered a new carb.
Installed new carb, cleaned out gas tank and line to carb. Fresh gas.
Tried to start – no go. Check that there is fuel in the carb bowl – yes.
Pull plug and place against head, can see spark when cranking.
Squirt in starting fluid – runs and dies.
Pull new carb and inspect, clean, blow out jet with air.
Check if needle is seating properly with compressed air when moving float – seems ok.
Swap o-ring between carb and intake manifold and reinstall.
Check for fuel in carb bowl – yes.
Try to start – no go.
Not sure where to go next, see above
Thanks!!!
Leakdown test?
Long(er) story -
Thanks!!!
