Hey guys,
New to the forum, but have been lurking for awhile. I'm having a major issue with my drive pulley on the right side. So I bought this unit used with 162 hrs on it. It now has 182 and I'm having to replace the Drive pulley/fan on the right side for a second time. First time I assumed was a fluke, but this time I'm thinking it's more serious. 1 reason being is last time I was able to get the nut off with a wrench and a ratchet, last night I was able to turn the nut a few round and now it feel like I may break the shaft it is on. I'm charging up my cordless impact, but assuming the worst here. Any Idea's why these things keep coming apart? In my case it appears the pulley starts to spin on the splined collar and when that happens it heats up melts the fan off and eventually the pulley center gets wore to nothing. Obviously I stop before it gets that far, but you get the idea. Between this and the deck clogging every mow I'm about to set this pos on fire.
