so.... the forums says small engine and mower.. hope someone can help me with my golfcart small engine because im not getting anywhere on my golf cart forums.
my golf cart starts and runs, then after running for sometime that could be up to a hour it will die and not start for several mins, has been as long as 10-20 mins before it will cough a couple times, backfire a couple times and then runs again.
my club car uses a fe290 kawasaki engine with a keihin carb
starts and runs fine.
1. randomly 3min to upwards of an hour it dies.
2. i have to crank and crank and crank before it goes again.
3. just before it starts it will cough a couple times and backfire.
4. then she sputters
5. runs and the process starts over again.
i have ........................
cleaned the carb
dipped the carbs over night
swapped gas pumps
new fuel lines
checked crank case pulse
restalled original gas pump as replacement didn't work any better
opened carb bowl drain to see if it has gas, and there is always gas in the bowl
would love some suggestions.
thanks john
cleaned the carb
swapped gas pumps
new fuel lines
thanks john
