mhavanti
- Oct 12, 2014
- Threads
- 12
- 924
I purchased replacement spindles for a 1998 MTD Yard Man All Wheel Steer, 42" cut lawn tractor. The original spindles had the start lug for the blades. The replacement spindle only has three lugs. The three lugs line up just fine, however, the lugs are a bit too wide at the outer most portion of the gear tooth making them more squared off than rounded.
Does anyone have this type of spindle with three drive lugs and what brand and model number are the blades for this type of spindle?
Thanks in advance,
Max
Thanks in advance,
Max
