Buying Advice Kawasaki or Briggs?
Tractorman47
I am about to purchase a Ferris IS600Z 48" cut zero turn mower, but I'm not sure which engine to get. I have a choice between a Kawasaki 18.5 HP, 603cc or a Briggs & Stratton Commercial 25 HP, 724cc. I can't find any negative info on either engine. The Kawasaki is about $300 more. Is the Kawasaki worth the extra money? Also, does anyone know if they both have the cylinder liners? Thanks for any info.
BlazNT
So 6.5 more hp and $300.00 cheaper. This is a no brainer.
BoylermanCT
I've had good luck with Briggs. My 24hp twin lawn tractor has 500 hours on it with nothing done except seasonal oil changes. I would also want the larger displacement engine. Theoretically it should put out more power, so overall work less compared to the smaller engine.
7394
I've had good luck with B&S, currently have a V-twin Kaw & love it. Kaw does have iron liners in my model. B&S commercial should too, (I'd think ?)
But I'd opt for the bigger power & save a few $$$
Mad Mackie
They both have cast iron cylinder liners.
Kawasaki and Briggs HP rating standards are different.
BlazNT
US government has a set of rules that require all engine manufactures to rate it the same way. How is your statement possible? Kawasaki has to follow the same rules as everybody else.
Mad Mackie
Can you elaborate on those rating standard differences ?
Quoted from the Ferris website.
"All power levels are stated gross horsepower at 3,600 RPM per SAE J1940 as rated by Briggs & Stratton."
"All power levels are stated gross horsepower per SAE J2723 as rated by Kawasaki."
So the HP ratings are not an "apples to apples" comparison.
B&S engines generally are rated with high numbers whereas Kawasaki engines are rated with conservative numbers.
I have looked at both of these SAE ratings in an attempt to see why the differences, too much engineering stuff for me to understand.
B&S doesn't make smaller HP twins in most of their lines so their options are higher HP.
Mad Mackie
Check out this info from Small Engine Warehouse.
  • Changes in Small Engine Horsepower Ratings.pdf
D
ddtkiengiang007
Guest
Nhavesinhgiare.com NhÃ* Vệ Sinh Công Cá»™ng Composite 1C TPX – Phục Vụ Công Trình Xây Dá»±ng
Hotline:
0933003329 - 0888 125 125 (Ms Phú Yên)
Công ty TPX (ThÃ*nh Phố Xanh) chuyên cung cấp (bán & cho thuê) các sản phẩm nhÃ* vệ sinh công cá»™ng Composite giá rẻ: 1C, 2C, 3C, 2A, 3A,...vÃ* bán nhÃ* tắm di Ä‘á»™ng, thùng rác composite, xe gom rác lÆ°u Ä‘á»™ng.
NhÃ* tắm di Ä‘á»™ng
Thùng rác công cộng Hải Cẩu
Nhiá»￾u loại kÃ*ch cỡ. Chất Liệu Composite siêu bá»￾n.
Tư vấn 24/7. Hãy Xem Ngay!
Ứng dụng: phục vụ các nhu cầu văn minh tiến bá»™ xã há»™i, đặc biệt trong lÄ©nh vá»±c xây dá»±ng, nhiệt Ä‘iện, môi trÆ°á»￾ng đô thị, du lịch, dầu khÃ*, năng lượng sạch, …
TẤT CẢ SẢN PHẨM Ä￾ỀU LÀM BẰNG CHẤT LIỆU "COMPOSITE" THEO CÔNG NGHỆ BẮC MỸ(được Ä‘iá»￾u hÃ*nh sản xuất trá»±c tiếp của các chuyên gia Canada)THÔNG Sá»￾ KỸ THUẬT:
NhÃ* Vệ Sinh Công Trình – 1C:
KÃ*ch thÆ°á»›c phủ bì:
1120 x 900 x 2600mm
KÃ*ch thÆ°á»›c lá»￾t lòng:
1060 x 850 x 1980mm
Dung tÃ*ch bồn nÆ°á»›c sạch:
300L
Dung tÃ*ch hầm phân tá»± hoại:
400L
Trá»￾ng lượng tịnh:
170Kg
Lắp đặt:
Sau khi có vị trÃ*, tiến hÃ*nh lắp ráp nhÃ* vệ sinh theo 3 bÆ°á»›c sau đây:
1. Nối ống nÆ°á»›c thải vá»›i ống thải chÃ*nh
2. Nối ống cấp nước với ống nước lên. Nếu nước mạnh quá, chỉnh van vừa phải
3. Tắt cầu dao rồi nối dây nguồn vÃ*o. Dây nóng nối vá»›i dây Ä‘á»￾. Dây nguá»™i nối vá»›i dây xanh.
Cam kết:
1. Báo Giá Trực Tiếp, Không Qua Trung Gian
2. Giá Cả Cạnh Tranh, Bảo Ä￾ảm Chất Lượng Sản Phẩm
3. Thá»￾i Gian Giao HÃ*ng Nhanh, Há»— Trợ Khách HÃ*ng Trong Quá Trình Sá»* Dụng.
"Vì 1 Môi TrÆ°á»￾ng Xanh - Năng Lượng Sạch":
MỌI CHI TIẾT XIN LIÊN HỆ:
Hotline: 0933 00 3329 – 0888 125 125CÔNG TY Cá»” PHẦN SẢN XUẤT Ä￾ẦU TƯ XÂY Dá»°NG THÀNH PHá»￾ XANH (TPX)Số 121/32 Trung Mỹ Tây 13, P. Trung Mỹ Tây, Q.12,TP.HCM
Ms Phú Yên – Phòng Kinh doanh
Email: nguyenphuyen2008@gmail.com
Fanpage: https://www.facebook.com/ctythanhphoxanh.tpxWebsite: http://nhavesinhgiare.com/
