12.5 Spraying oil and gas from carb
TheRealHenry
Motor ran great, put it away after a cut.
Next time I tried to start it, it fired right up but then immediately died. I took the airbox off and tried again.
Again it fired right up but then started spitting a gas and oil mix out of the airbox and died.
What's going on here? I'm confused how this could occur especially after it ran fine before it was parked.
pugaltitude
If its oil in the air filter then it sounds like your head gasket has blown between the cylinder and the valve chamber.
Supply the model, type and code of engine to check its that first.
Tinkerer200
Didn't check the oil level before starting did you? Float needle probably leaked filling the crankcase with gas
Walt Conner
TheRealHenry
Walt Conner
I believe this is exactly what has happened. I worked on the mower a little more yesterday and found the oil is full of gas.
Do I need to rebuild the carb? I'm very unfamiliar with the 12.5. Mower was bought second hand.
Yes you will need to change the oil twice to gte rid of the gas
You will need to rectify the leaking carb by fixing the float needle.
how you do this will depend upon what motor & what carb you have.
Thus Plugs request for numbers.
You might also like to fit an in line fuel tap between the gas tank & the fuel pump or fuel filter depenfing upon the model.
Belts and braces approach but $ 5.00 says a lot of stuffing around.
Note you will still have to clean the carb or the engine will flood while you are driving but at least in future you will not need to do a double oil change.
When you get it running , check the dip stick tube and the crankcase breather in the air cleaner.
You might need to run it for 1/2 hour or so to clean the crud out.
If it blows a lot of oily fume into the air filter or smoke signals from the breather tube then the head gasket is gone.
upupandaway
As Berts said, yes it is a carb leaking problem but the fix may be simple.
These carbs on 12.5's i have come across that clean and replacing the float needle does not rectify the problem and i have resorted to adding a shutoff valve as a result.
If i were you, change the oil then take it for a spin and cut grass to see if it does indeed flood while running thus need rebuild\clean carb or else KIS and add a shutoff to prevent this again.
For myself,clean\replace never solved my problem so valve it is.
TheRealHenry
Model: 28U707
Type: 1113-E2
Code: 030516Z0
Can someone explain what exactly the shutoff valve would do that will rectify the problem?
pugaltitude
Fuel shut off valve or fuel tap will stop fuel flow when not in use.
The needle in the carb dont always seal which then
allows fuel to leak past and fill engine up with fuel where the oil is supposed to be.
TheRealHenry
So simply by installing the valve and keeping it off when the mower is not in use, I can fix the problem?
I will not fix your current problem but it will prevent it hapening again.
You might be lucky and have not done any engine damage.
You won't know this till you have cleaned out your engine and tried it .
