I own a 2012 52 inch Husqvarna garden tractor. Model GTH24V52LS. The anti sway rod came off . I did not know that it was off until I was cleaning the leaves of the deck and found it lying there. It was bent. I did straighten it and tried to place it across the deck into the holes that it had come out of but it seemed to be s little short, so I figured that I didn't straighten it like a new one that's why it was short.
I'll get to the problem, I received a new anti sway rod yesterday and it was short. I eyeballed the main brackets and they seem to be straight and not bent. Has anyone replace an anti sway rod on a Husk mower deck? It seems to mow ok, will mowing with it off hurt the deck? Do I need to take the deck off to get a better look at the brackets?
I did place both anti sway rods side by side and they are the same. Any help would be appreciated. Thanks Willyp
PS Located info on page 20 in owners manual, Thanks guys
