Valve lash on Briggs 15.5 HP I/C engine. Series 28000
wilburn cox
  • / Valve lash on Briggs 15.5 HP I/C engine. Series 28000
I may be confused which happens a lot.. I just saw a post/thread from someone about setting valves on a 15.5 HP I/C OHV Briggs engine. The gentleman said he set both valves at .004.
I have the same engine on my Murray rider series 28000 and my repair manual shows INTAKE VALVE .003--.005 and EXHAUST VALVE .009--.0011. I was adjusting my valves this morning and decided to search for valve lash numbers on the web. and found those same adjustment numbers.
Which adjustment is correct. I am not an expert but do all of service work on my three mowers.
Any help is appreciated.
Red Cox
Fish
You need to get into the habit of posting the full/correct model-type-code numbers, if you want to fix your mowers correctly.
Fish
Overhead valve adjustments are totally different from old flathead adjustments....
wilburn cox
My apologies Fish.. Model # 282H07 -----Type # 0196E1 -------Code 058217ZD.. I will try to do better on this..
Red
Fish
No problem, but the model numbers do nothing but throw more light on everything.
