John Deere Owner Check-In --- Read This First!
Hammerdown
Hello
I have been a member for a while but I just Noticed this thread. I have owned Nothing but John Deere lawn & garden Tractor's for the past 30 Year's. Many have passed through my hand's but my current 1983 John Deere 318 is here to stay. I have had it about Seven year's now I found it at a John Deere Tri-Agri dealerhip in the back row and paid $300.00 for it whole sale. It came to me with a about new 48" Replacement deck that retails alone for $1300.00. I used it about Five and a half year's with no mechanical issues but decided that it was time to take it down and restore it as it's original engine was getting tired. I stripped it to the rolling Chassis Painted the frame and wheels as well as all of the body panels. I had a brand new Onan P-218 engine built for it to complete the restoration. I added an Upgraded suspension style seat as well as bar tires and wheel weight's to it. A couple of Year's ago I located a model 30 Hydraulic tiller for it that I traveled 1250 Miles in 23 Hours to bring back home. Last year I found a Model 54 Four way hydraulic blade that needed to be restored that I gave $100.00 and restored it. My son in law drove me nut's to sell my 318 to him but being so pleased with it, that sure was Not going to happen so recently I located him a 1991 John Deere 316 Tractor. I found it on our local Craig's List advertised as a 1991 John Deere 316 not running with a 50" mowing deck, extra floor pan and power flow Bagger attachment for $200.00. The add was Just Five minutes old when I called the seller and told him that I would take it. It was a 200 Mile trip to get it and was very, Very rough when I got there to se it. It had spent most of it's life in Stuart, Florida very close to the Ocean so when it's Factory powder coat paint failed the salt air did a Job on all of it's metal panels. I asked the seller if he minded if I checked out it's Onan P-218 engine ? he said that as fine so I hooked up a set of Jumper cables and tried to start it. The engine would Not turn over, so I told him it was no more than a Part's Tractor to me and he dropped his price to $75.00. I then offered him $50.00 for it and he accepted. as we were standing there I heard a click noise and noticed that it's Hour meter was working and that it showed to have 349.2 Hour's on it. I then spotted it's steering wheel Nubbies along the rim of the steering wheel still protruding where as they are worn smooth on my 318 so I figured that the Tractor was a low hour machine. I Paid him quickly and we loaded it up. Once I got it home I discovered that someone had cut the starter wire and placed it on the hot side of the battery cable, where it should have run from it's circuit breaker down to the hot lug of the starter. I put it back where it belonged and the engine turned over with the key. I squirted some Either into it and cranked the engine and it came to life. I then unhooked it's gas line and Placed it into my 2-1/2 Gallon gas can and it started up and ran great. That was when I decided to build it for my son in law. I took it down to the rolling Chassis, Took The engine out of it so that I could paint inside of it's frame rails painted it's frame and wheel's then repaired two hydraulic leak's that it had and cleaned it's carburetor as well as adjusted it's hydro lever linkage. The 50" Mowing deck was destroyed as it was bent badly and cracked from top to bottom so we Purchased a John Deere 317 part's Tractor that I used the 48" mowing deck off of it for this Tractor. I had to Transfer all of the blade spindle assemblies from the 50" deck to the 48" deck as the bearings were bad, Then I sanded it down and gave it Three coat's of John Deere Yellow paint. I sanded down all of it's badly rusted and Pitted body panels and used a Gallon of Body filler in it's badly Pitted floor pan and body panels to fill in all of the deep pits and Gave it Three coat's of John Deere green paint. I bought a new john Deere seat replacement cushion kit for it to finish off the Project. my son in law has Just $632.00 in this Tractor completed and as shown. Regards, Hammerdown
Here is my recent 1991 John Deere build that I did for my son in law. This is how it looked the day I brought it home. it was Not far from being scrapped but I felt it was worth saving with Just 349.2 Hour's on it hour meter this Tractor had a Lot of Life left in it even though it Looked rough from the start when I brought it home I feel that it turned out nice in the end of the 6-1/2 week project of bring it back to a Useable Tractor again
Here it is shown next to my 1983 Restored john Deere 318. We Both Now have Tractor's that will last us a Lifetime
Here is my 1983 John Deere 318 shown with it's restored 54" dirt dozer blade as well as it's Model 30 Hydraulic tiller.
PJ
Hello I have been a member for awhile but just Noticed this thread. I have owned nothing but John Deere lawn & garden Tractor's for the past 30 Years. Many have passed through my hands but I am now satisfied with my First year 1983-John Deere 318. I have had it about seven year's and a year and a half ago I decided to take it down for a restoration. I bought it from a John Deere Tri-Agri dealership for $300.00 whole sale it came to me with an almost New Replacement 48" mowing deck. When I restored it I had a brand new Onan P-218 built for it, painted it's rolling Chassis along with all of it's body panels. I upgraded it's seat with a newer style added a new John Deere seat replacement cushion kit,. and added a set of Rear wheel weight's that I bought used from my John Deere dealer for $30.00 I located a Model 30 Hydraulic tiller for it that I travled 1250 Miles round trip to pick up and found a 54" dirt dozer four way hydraulic Blade that I restored as well that I gave $100.00 for. My son in law has drove me nut's to sell my 318 to him, so recently I located a low hour 1991 John Dere 316 for him that we also restored that had only 349.2 Hour's on it original hour meter, it too has the Factory Onan P-218 engine in it. It was Really rough and not that far from being scrapped but I felt it's low hour's warranted a complete restore. It took me 6-1/2 weeks to complete and he has just $632.00 in it completed as shown. Regards, Hammerdown This is my restored John Dere 318 sitting beside the recent 1991 John Deere 316 that we restored for my son in Law Here is how the 1991 John Deere 316 Looked the day that I brought it home and gave $50.00 for it Not running
Hi
It looks very nice better than a new tractor makes one feel good after you complete such a project
PJ
MidTNDawg
I've been around here a month or two, but here goes; I'm a retired JD L&G collector, do several parades & shows in North MO & some in Southern IA.
Below are my 71-110, 74-112, 69 140 w/Johnson loader (now sold), 83-420, 9? F525, 82-317"Special" & 69 L/60 "Custom":
Very nice even this much later. LOL
Deereman148
I just joined the other day so I'm very new to this. I'm a brand new home owner with my n 2 boys. I love John Deere products and my wife let me get a brand new lawn mower for my anniversary gift. Now I'm learning how to get my lawn looking green and nice! I have a D105 riding mower with the dump cart with it!
PJ
I just joined the other day so I'm very new to this. I'm a brand new home owner with my n 2 boys. I love John Deere products and my wife let me get a brand new lawn mower for my anniversary gift. Now I'm learning how to get my lawn looking green and nice! I have a D105 riding mower with the dump cart with it! <img src="http://www.lawnmowerforum.com/attachments/john-deere-forum/20197-john-deere-owner-check-read-first-image-1929126935-jpg"/>
Welcome to the forum may you have many good seasons with your John Deere.
PJ
Eck
New-be here
Greetings all..
My name is Eck. Live in Huntsville, Al.
Purchased a used John Deere LA105 that looked kind of ragged, but after spending a few hours cleaning and waxing it up, I took a few photos.
Already purchased a new seat and replaced it since previous owners dog wanted the old one for lunch.
24jeffg
shawn,,, john deere lx178.
y112
Hello from upper West Hemlock Township! I own a 317 and 318 that get used hard. Looking to do some repairs and upgrades to both. Looking forward to reading this column for advice.
I didn't see a used parts section, but I have a cart bagger that came with the 318 that I'm not using and will sell or trade if any one is interested.
jwyatt77
Maybe you can help me. I have a Model N21SJ mower and wondered if it is worth anything. It runs just fine.
rangid
Hello all; Not usually a poster to forums, just a lurker trying to glean from knowledgeable users in hopes of getting repair info.
I work in television but my hobby is lawn equipment repair and use. I also cut several yards in my neighborhood for extra spending cash.
Started working on my own Snapper RER. After getting comfortable with working on it I started flipping mowers found on CL.
Then a couple of weeks ago this JD X300 shows up on CL for $100; sold as parts machine. When I inquired why parts he told me he parked it last year when he couldn't get the mower's pto to work with the switch.
The mower has been out in the elements since new in 2008 so I expected there would be issues with it since I couldn't get it started at the sellers house. But I now have it running after MUCH studying of the Tech manual and trouble shooting wiring issues.
I'm on a quest to get this machine 100% operational while trying to keep the spend on the down low. Therefore I don't like to throw shotgun purchases of parts trying to get things fixed.
So I'll be posting a question regarding the PTO issue I'm having shortly.
Thanks for a great forum and for everyone willing to help others with the passion to make things work as they should.
Randy
