L130 Just stopped mowing mid mow
moep43
hello all!
I was hopping some of you may have some insight as to what the hell just happened! I was mowing along with my L130 and all of a sudden....the blades stopped turning. I turned off the deck, tried to turn it back on and nothing. So I jumped out of the seat to check the belts and the first thing I noticed was that the mower did not turn off like it normally does....I turned the mower off and inspected the belts everything seems fine. I jumped back in the seat and figured maybe my safety circuit had got bad however I still had to push in the break to start the mower...
Im not sure where to start here....deck wont engage and the pressure switch on the seat doesn't work has to be a common denominator here right???
Any insight would be helpful
Thanks
Moe
BBO
Does the switch work or not? Will it crank at all?
