When I flip on my PTO switch the mower engages and then goes off. If I keep presure on the switch, the mower deck keeps running, the miniute I take it off, it stops. -- not sure if its a switch , belt or clutch problem.
I was having trouble with my PTO switch. I went the implement store and they said the PTO switch would cost $52.00. That seemed high for a PTO switch (they might be taking me to the cleaners). Last night I put the old PTO switch back in the mower and as long as I put presure on the switch it worked. I stopped the mower and then when I tried to restart it it would not do anything. I want to make sure the PTO switch is the reason its not starting. This is an old mower and $52.00 is a lot for little switch. The battery is brand new and is charged. If it is the PTO switch I will change that, but before I do that I want to make sure that is the problem. Need some direction on proper trouble shooting.
