hackney502
- Apr 30, 2020
- 2
- 4
I have a simplicity champion ZT-20H 50" mower. The left wheel does not pull as good as the right wheel, especially when turn right up a very slight grade. I've checked all the linkages (they seem ok), replaced the drive belt and made sure it is installed correctly, checked the fluid level ( ok), tire pressures ok, . Both wheels seem to be spinning at the same speed when jacked up. Have not changed hydro filter yet. Any suggestions? Thanks
