I have a 2010 Z710a 54 zero turn mower that has developed a hydraulic leak on both sides. I have searched every way I know of to find a good schematic with part numbers so that I can get it repaired to no avail. The leak is coming from the top side of the transmission toward the rear of the mower just behind the fan on top (same place on both sides). It is a low pressure leak. With the mower stopped and cold I can fill up the hydraulic tank and it will completely drain over a relatively short time. The mower still works well with no apparent operational issues other than the leak, but the leak is becoming a problem. Started small and has gotten worse over the last couple of weeks. I sort of check the gas and fill it up with hydraulic oil every so often while mowing. I can't afford to have this thing stuck at the dealer for weeks and spend thousands for them to fix it. Any ideas would be greatly appreciate. Thanks in advance.
