Hi guys,
New to the forum and would appreciate any help you can give.
I have a Z345R that is going on it’s 3rd season and about halfway through the 2nd it intermittently wouldn’t start or would be so down on power it would stall if I engaged the blades. It acts like a vapor lock issue. If I disconnect any of the fuel lines from the pump and reconnect them without doing anything else, it will run fine for quite awhile. Is this the fuel pump, the cap, a clogged vent line, or something else entirely?
Thanks again for the help.
