X-BLADES / CROSS-BLADE SET UP??
SweetPowder
I am new to the forum and ZTR mowers. I would like input regarding setting up X-blades / cross-blades from anyone who has set-up their mower(s) this way. Running a Kubota ZD1511 with a 72 inch side discharge deck with factory installed lift blades. I am interested in putting on (adding) a set of mulching blades to reduce the size of the materials being discharged. Should the mulching blades be installed above / on top of the lift blades, or below the lift blades? Thank you
Darryl G
Not sure it really matters, but I would put the mulchers up top. I wouldn't really recommend running double blades with a high lift and mulching blade combo though. It's going to sound like a freaking helicopter and throw the grass 3 to 4 mower widths and put a lot of strain on the belt and PTO. Your deck will likely quickly pack with grass too. If you're intent on using double blades I'd recommend running a combo of low lift blades and either a wavy mulcher or Gator-type mulching blades. If you do run double blades, they should be precision balanced and you should make sure that your bolts are long enough. Note that you'll be cutting lower so you'll have to raise your deck up a notch.
Instead of double blades I'd recommend trying a single set of Gator G5 or G6 blades. They reduce clipping size and still have enough lift to discharge well and provide a decent cut. They're wider than standard blades so they can get more of a "sail" or air foil on them. Basically, they're high-lift mulching blades. The G5 and G6 are the same design but the G6 is made of thicker steel for increased durability and are very heavy. Both are pretty heavy in fact and require a machine with sufficient engine power.
Ken 22
How did you make out with cross blading. Last fall I cross bladed my ZTR and it Sure a job on the leaves. I used the blades that came with the Gravely. Really hard on the clutch. This year I'm going to cross blade my 60" pull behind that has a manual engage.
