Which type of gas would you buy for your 2 cycle equipment?
Which Type of Gas Would you Buy for Your 2 Cycle Equipment?
  • Regular Non Ethanol
    Votes: 45 70.3%
  • 93 With Ethanol
    Votes: 8 12.5%
  • 89 With Ethanol
    Votes: 11 17.2%
  • Total voters
    64
exotion
I run 89 with ethonol should add.that to vote
Ric
I run 93 with ethanol in everything including the truck.
Mike88se
I've never had a problem with 87 but I've only been mowing for 3 to 4 years. Are these engines designed for premium gas? Coming from a car background, the only engines that need premium are high compression/high horsepower engines. The reason for that is to deter pre-detonation. Higher octane gas burns slower. In a car this might mean incomplete combustion and deposits and frequent cat and o2 sensor replacement. Premium gas needs high compression to burn completely. Running premium in the average car/truck engine is not only a waste of money, it also has a possibility of harming your engine with carbon deposits etc.
Back to the point... I don't know that these engines are high compression. I'd guess that the fact they are air cooled and have oil mixed in the fuel would affect things too.
Bottom line, I do think that the ethanol is a bigger factor than the octane rating.
Parkmower
This is why I run regular old 87 in everything. This is another topic like "what oil or brand mower" but your explanation is the reason I run what I run.
jekjr
I run 87 with Ethanol in my Kubota ZG most of the time. I run non ethanol in my hand held and my Crapsman tractor. I also have run both in my generator and in my Tiller.
panabiker
I use 87 octane with unspecified amount of ethanol (hopefully less than 20%).
