Troy-Bilt Trail Blazer Sickle Bar Mower Carb Info needed
Orangegud
  • / Troy-Bilt Trail Blazer Sickle Bar Mower Carb Info needed
I have a T. B. sickle bar mower M #15003 / 4 h.p. and is in need of a little engine re build. where can i find out what type of carb this is for a re-build kit and any and other info on this machine. I've got the manual, but limited info.
Scrubcadet10
Moderator
Staff member
You will need the engine model numbers If It's a Briggs and Stratton engine they should be stamped around the spark plug or the muffler on the metal blower housing
