tecumseh hh60 leaking oil around the governor shaft ! how to repair! any ideas
geralsc3
  • / tecumseh hh60 leaking oil around the governor shaft ! how to repair! any ideas
help please ! governor shaft leaking oil ! tecumseh hh60
Romore
It will likely be weeping, really not much you can do about it. You could disassemble the engine and have a bushing machined to fit but is it worth the effort?
Two threads, same poster, same problem, very confusing???
