Stihl BR340
Uncle Dave
Need advice. I have a still br340 blower, runs great for 30-45 mins then Boggs down. Cuts off. I start again it runs 10 mins. After 4th 5th time won't crank. I've changed gas, plug, air filter, tank filter,exhaust screen cleaned/torched it. Any suggestions appreciated.
tom3
Does the engine tighten up, can't pull the rope? Or just won't run? I have a couple 2 stroke machines that will lean out after several minutes and need the high speed mixture adjusted some, worse on a hot day. Just a quirk of the cheap carbs I suspect.
The fuel tank & carb run at 7 psi
This pressure is regulated by either the cap or a tank vent or both.
If it not regulated then the tank overpressurizes and the engine floods after a short while.
A 2 stroke will make very different noises when stalling rich as comparred to stalling lean.
If the vent /cap is blocked it will flood & stall rich ( Bog down, 4 stroke, miss a bit then stop )
If they are leaking then it will run lean which will cause the exhaust note to become quite sharp & harsh then the engine will race away then die.
The final entry on the usual suspects list is a partially blocked screen in the muffler which prevents all of the exhaust getting out till the engine eventually chokes on it's own exhaust, however this usually happens after 3 to 4 minutes but always worth a check
When the engine gets to where it doesn't restart make sure you still have spark at the spark plug. These symptoms can also mimic the results of a failed ignition module.
Uncle Dave
ThanksTom
Uncle Dave
Thanks
Fish
Take off the muffler and peek at the piston.
