Regarding that little, spring loaded arm in between the cam gear and the first lobe, what does it do and how important is it to have it working? My arm is fine, but the spring is flopping about and may be partially broken. As it's super thin, I think I could make in work by re-bending it. Won't bother if it's not terribly important. TIA
