Small Zero Turn Options W/Bagger
bmo99
Hello, I am looking for recommendations on a Small Zero Turn to purchase. I am looking for something under the standard 42 inch size. 42 inch does not work for me because I will need a bagger and most bagger attachments wont fit through my 46 inch gate. The only two options I've found are the Snapper 360z and Hustler Dash 34. Are there any other options available that I am missing? I would like to stay under $3000. Just over 1/2 acre lot.
SoCalRedTractor
I'm looking for the same solution - my budget might be a little more "flexible". I'm targeting the Ariens Edge 34 - with the 2 bag unit - I was told by Ariens it would come in at 46" wide. I'm also looking at perhaps a 42" w/bagger, but just removing the hose/tube (not sure if that's viable) to get it thru the gate.
Pick
gotomow
You guys looking at ZTR and bagging make sure the engine has excellent air filtration.
SoCalRedTractor
Okay. But, what does that mean? Wouldn't the mfgr. have that dialed in already if they offer a bagger accessory for the model? Or, are you referring to the area using it in with dust etc.?
Pick
gotomow
Pick
Leaf collection is very dusty conditions and air intake is back there. Sometimes cost concessions dictate optimum performance so buyer beware
Bobbydonchakno
Just going through the forum and found this thread. Out of curiosity, what did you go with? I have a 34 inch hustler dash and am purchasing the bagger. If you went that route how did it work out? Thanks!
