Ryobi Mower Strange Noise
Jake8131
Question: When my RY401110-Y mower shuts off sometimes it makes a grinding sound. Any idea. Blade was just changed.
sgkent
I'd make sure every thing that is supposed to be lubricated on a regular basis is up to date. Get in touch with your senses as to where the sound and vibration is loudest. Does it do it only when the blade slows down, does it only do it when the engine is in neutral and it is turned off, etc..
Jake8131
Only randomly makes this noise when I let go of the handle to shut the mower off.
MowerMike
You said you just changed the blade. Are you sure you installed and tightened it properly.
Jake8131
Pretty sure. Can do it again and let you guys know.
1 Lucky Texan
does it do this only on concrete or also in the yard?
wondering if a wheel just barely not touching could vibrate and do this?
Jake8131
Took the blade off and it balanced perfectly, however, the nut that goes on started to turn round and round. Have to get a new nut, but used thread lock on it and it is holding ok..no more shut down noise.
