Buying Advice Royal Purple 2 Cycle oil
Kodie's Lawn Service
So i was looking around today and ended up buying royal purple 2 cycle Sentatic Oil Anyone ever used it is it any good??? I know they make good 30w oil and 10w 30 :anyone::anyone::anyone::anyone:
benski
I'll bet you'll be fine. I'm also a big fan of the correct Amsoil 2-stroke mix.:smile:
Thanks I hope so I know they make great oil for other thing hope to see the same out of this
KennyV
Royal Purple is a good Brand...
Any synthetic is going to be lightyears ahead of mineral, you should have no oil related problems... :smile:KennyV
man00
1.2.3......
jekjr
I never used it in a car or in mixing oil. HOWEVER I worked in the Pulp and Paper industry and I have seen gearboxes that would be running very hot. We wold shut them down, drain the regular oil out of them and install Royal Purple and start them right back up and they wold run at a normal temp. Seen that happen numerous times.
It just got here I gotta get gas soon gonna try it out here in a couple of days will report back about my first thoughts
Boudreaux
I read many posts in various Lawn Care Forums. I read in one post the mention of Echo 2-Stroke oil having additives to aid in combating Ethanol fuel. I tried finding this info and failed.
Has anyone heard of this.....???
