racing mower help needed asap
justinsargalis
Hello i am new to this forum and am having difficulties removing the front pulley off of the motor shaft. i have gotten a 3 pronged pulley puller and i am just bending the pulley to all hell and beck. i also have removed the bolt holding the pulley into the shaft so its not holding anything in. any ideas or suggestions before i take the sawzall and grinder wheel out thanks
-Justin
Mwh0428
Use pb blaster and spray it on the top of the pulley, let it soak for a bit then try, if that dose not work then heat it up with a torch.
