Push mower keeps stopping
Jbanister98
Hi, I have a MTD 21" self-propelled 139cc OHV push mower. It runs strong for 10 minutes or so then stops. If I wait 15-30 minutes I can usually get the last 10 minutes of mowing done. I have such a small yard and this is really frustrating. I have replaced the spark plug, changed the oil, air filter, fuel filter and fuel line. I've also pulled out the carburetor and it looks clean. I'm imagining that it's overheating but I don't know what else to do to help with that. Any suggestions would be appreciated.
Next time it happens loosen the gas cap. If the engine regains it’s power your cap is bad. You the engine stops remove the cap and then reinstall. If you can restart right away and cut for another 10 minutes, again cap is bad.
Scrubcadet10
Moderator
Staff member
Do what rivets said, but if no luck, I would suspect a faulty ignition coil failing when it heats up.
When it dies, does it sputter and spit, or just like you flipped a switch and it's off?
Jbanister98
Thank you I will try this on my next mowing attempt.
Jbanister98
It sputters for a few seconds then dies.
Jbanister98
Okay, so new gas cap didn't change anything. Mowed for 10 minutes then sputtered and died. Is the ignition coil my last option?
Scrubcadet10
Moderator
Staff member
It sure sounds like it, especially since you said you have to wait about 15 minutes to cool down...
That's what I would do..
Another option is to buy an inline spark tester and check for spark after it dies...
Jbanister98
Just got a new ignition coil today. I'll post after I install it and try again. Here's hoping it works.
Fish
Sounds like it needs a valve adjustment.
Jbanister98
I give up, ignition coil installed and it only want 8 minutes. If it needs a valve adjustment I'll have to take it on somewhere and after that money and all the parts I've put into it I might as well just get a new one. I'll sell this one to someone that knows how to fix it or wants it for parts. So frustrating. Thank you all for your suggestions.
