You can also check the coils using a DVM on OHM setting,,the factory has certain specs. on the resistance of a good coil VS. a bad/weak one.
You can only check the secondary side of some coils with DVM which is why you no longer find resistance readings for them in most service manuals.
Back in the points days yes
Now in the Hall effect electronic triggers no
This is why they are now called ignition modules and not ignition coils, also why they cost 10 times as much.
I repair engines for a living and have a dozen different in line testers but the one I use most is the simple neon tube with a lead at both ends.
They fit anywhere, you can usually hold them with a cable tie or 2 so you can see them easily while on the mower.
In the shop if the engine has failed the neon tube test I put a better one on, either a Briggs 3 point or a variable gap but neither of these are suitable for using while you are mowing.
