Pony Not getting Electric Power
a_cmc_2b
I have a Troy Built Pony Model #: 13WM77KS011 with a Build Date of 06/16 and it is apparently not getting any electricity. It doesn't click or anything when you turn the Key. The 20 Amp fuse by the battery is good as is the battery. I can find no damaged nor disconnected wires.
I have not took my test light and started checking from the battery forward, but am hoping some of y'all will know of a common problem with these little mowers that cause my problem.
Troy Bilt Riding Mower - Model Number - Serial Number Identification Tag - A.jpg
Battery > fuse > key switch > PTO switch > Parking brake switch > solenoid trigger wire
One of the links is broken.
