Please help - lawn tractor - no power
levesqueonline
So I was in a rush and hooked the terminals up wrong on my battery. turned key, nothing happened, no clicking or sound. I quickly figured out I hooked it up wrong and fixed. Still no power. The hour meter has no power, the headlights don't come on. Its first start of the season so not sure if something more is a foot but... giving all details.
I read online a while and found the main fuse, it was burned out, so I replaced that. Tested battery and solenoid, all showing 13V (fresh charge) but still no power to headlights or the hours meter.
any thoughts? the fuse is a 25 so its not yellow like the other, i can get another 20 incase this one isnt good but it looks fine.
Craftsman T3200 with 24HP briggs. all google videos are based off can't start, not around no power at all to accessories, which is root cause of can't start im sure.
Model number under seat please, I really, really hate guessing.
levesqueonline
Found some good guides online, turns out the replacement fuse was bad tested with multimeter, got new one and now have power back, thanks again for diagram
