B&S 6 HP push mower. I only can get it to start with starting fluid. It'll run for a few seconds then die. I've taken the carb off and cleaned with carb cleaner....still no luck. Would a weak ingnition spark cause similar symtoms? If so, any suggestions on futher testing to pin point my problem. Thanks and have a great day!:smile:
