Stryped
- Apr 12, 2022
- 10
- 45
I have a 27 hp Briggs v twin with aluminum rods. I broke a rod so I am rebuilding it. It goes to my lawn mower.
Can you tell me what to look for in terms of clearance between my rod and crank journal? If the clearance is too much, can I mill the rod halves to make the large rod journal smaller if that makes sense? Could it be done with sand paper and plate glass like you use to flatten a cylinder head surface? Thanks for your help!
