Need help identifying my TimberBear?
forgetaboudit
Hey guys,
I got this McCulloch TimberBear for free from a customer who couldn't get it running. I took it home, replaced the clogged air filter, blew all the crud out of it, and adjusted the carb. Now she runs like a dream! But I can't seem to find the model number ANYWHERE on this beast. If anyone here could help me out I'd greatly appreciate it!
Timber Bear is the generic model number. There should be a tag some place starting with 13- it is a 3.75 cu in 60 cc saw from around 1990. If I remember correctly was the same saw as the Pro Mac 610
willys55
Timber Bear is the model, 1990 to 1993 1/2 uses smaller diameter crankshaft taper for the clutch hub and chain gear. What part do you need. standard chain and bar is 20" with 3/8" 72 chain
willys55
the other difference is the engine is a 3.7cc, the 605,610 are 3.4cc
forgetaboudit
Ive downloaded a manual for the timber bear, but it says it has an automatic oiler. My saw has an oiler pump button next to the handle...
Im new to chainsaws...
Most have both.
Well both of my timber Bears have both a manual and an automatic oiler and both are fitted with a hard nose bar so you give it 3 or 4 pumps, rotate the chain 1/3 do the same then repeat again to get the chain nice & oily before you put a load on the bar
willys55
no one has mentioned this, but you have the aftermarket oregon bar on the saw, it has a kickback wheel that needs to be greased you will see a small pinhole just below the rivets for the sprocket, and you can get a needle greaser from tractor supply or sears
