LawnWizard
- Nov 17, 2021
- 14
- 96
Just completed a longblock swap. Have everything back together. Engine started with a shot of starting fluid. Ran perfectly, smooth idle, smooth at 50% (didn't try to run at wot yet). Shut it down and restarted several times perfectly. Let it set about an hour now will not start. Replaced carb, same result.Turns good, good spark on both cyls starting fluid does not help. Good compression when turning by hand. Tried the choke in several positions, no difference. With spark, fuel and compression, shouldn't it at least fire and try to start? Puzzled. Any suggestions are greatly appreciated!
